i have run a check and apparently i have a good connection, but the TV light is not lit and i have not got an TalkTalk TV service.
this has been since around 1600 this evening.
the "chat" isn't replying!
Are you getting any error message? Are you using powerline adapters?
Hi systemdown
If you can answer the questions from ferguson, and also add your home number to your Community Profile, we can take a look.
yes, there is an error message, it says i'm not connected to the interent, but i am, and have run a speedcheck which says it's a fast connection.
yes, i am using powerline adapters and they seem to be working ok.
all lights on the adapters are green.
the issue is intermitant and mostly happens in the evening (although, that's the only time i tend to watch the TV anyway)
I'm nor seeing any issues remotely. I've a router on the way to rule this out.
When the connection drops, check your internet connection and also check the home phone at that time for any noise or interference on the line.
