old you view box
11 REPLIES 11
Sightseer
my box is very old and i am sick off having to switch it on and off all the time
What actually is the issue you face with the box? What model is it? This can be found under device information in settings.
there are things that can be tried that may help any issues you are having.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
Hope it works but if not then please let us know and I’ll flag for further assistance.
Sightseer
model number DN370T.02.04.P  It freezes and i have to turn it off at the back if you stop half way through a film when when you go to watch again it start at the beginning this is all the time
I've escalated to the OCE for you, but have you tried the maintenance reset I suggested?
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
If you are unsure of your phone number, you can find this in My Account or dial 17070 from your land line phone and this will confirm the number for you.
Thank you
Hi sandyb22
Can you please add your home phone number or Account number to your Community Profile so I can locate your details.
If unsure of your phone number, simply dial 17070 from your land line phone and this will confirm the number for you.
Sightseer
my account number is REMOVED FOR SECURITY
Hi sandyb22
I've ordered you a replacement TV Box, please allow 24-48hrs for this to arrive.
Sightseer
  • thank you i received my new box today but there is no remote control
Hi sandyb22
Your old remote control will work with the new box, the replacement TV boxes don't come with a remote control.
Visitor
This is exactly the same with me - the box will cut out half way through a film, and almost certainly before the start of a new Netflix episode. I have had the box almost 3 years.
Recently, in an attempt to speed up, I upgraded to the fastest ever broadband, but this has not impacted my TV watching experience.
I bought a new remote last month, thinking this may fix some of the suppppppper slow connectivity, but alas, if anything the box has gone slower. You can waste seconds upon seconds waiting for the TV box to catch up with what you've pressed on the remote... and then waste more time correcting the zealous over-pressing :)))
I will try the options listed above to see if the Box functionality becomes any quicker.
I would appreciate any other advise or support.
Dillon Heffernan
Hi @HefferD
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
Hi @HefferD
Please can you create a new topic on the Community, we can then look into this further.
