Search instead for
picture distortion on BBC 1 and 2
tedtill
I am having picture distortion on BBC 1 and 2.  I have tried all the suggestions on support.com with no luck.  I suspect the You View Box
If the only channels affected are BBC 1 & 2 then it may b a freeview signal issue.
Have you tried a full retune?  Do you have a standard freeview TV you can test bypassing the youview box ?
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
MugMan
We have the same issue. You can get the one HD and all the other channels, but not the normal BBC channels. This happens now and then. I normally switch to the TV's freeview and its fine, so it has something to do with the youview! I do find talktalk services very poor.
