tv box
1 REPLY 1
trishp
My ethernet cable from router to tv box is not long enough. Are they universal and where can I get a longer one. Thanks
fre55die
Hi @trishp
Yes the ethernet or RJ45 (to give them their proper title) are universal. I buy mine from AMAZON, they're very cheap usually including free delivery from third party sellers. Do check the reviews and that they are RJ45's as there are a number of similar looking leads which will not work.
https://www.amazon.co.uk/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=ethernet+cables
