youview box
1 REPLY 1
helenmacari
can I connect my you view box wirelessly
Officially, no.
however there is a way to do it as some have found but it involves a bridge and even then it does not always work. You'd be best doing a Google search to find how.
best way is to use powerplugs
official comment from YouView here. https://support.youview.com/youview-box/set-up/using-wi-fi-to-connect-your-box/
