DHP-W610AV needs frequent reboot
DarekK
DHP-W610AV needs frequent reboot. More-less every day.  Normal operation provides reasonable connection over the power network with ping delay 3 - 5 ms. Unfortunately this plunges down suddenly to variable 100 - 300 ms. This results in very slow, unresponsive connection to internet and poor stuttering streaming within home network.Reboot instantly restores correct operation. But whole thing becomes laughing stock.
Any hints what might help?
hosay299
@DarekK  welcome best to post in service selection and ur will get help their for a fix
Under the relevant area as broadband or fibre
Hope that help Regards Joe
fre55die
Hi @DarekK
As @hosay299 has said, could you re-post on either the TV or Broadband sections of the forum as this is a rarely monitored section and is unlikely to be seen by an OCE, I can't even escalate it for you from here.
IMPORTANT !!!!!!
