Plume trial
1 REPLY 1
I'm interested in the Plume trial. We live in a three storey cottage, with a bedroom and my office on the third storey.
WiFi signal is poor on the top floor, despite me having the latest TalkTalk WiFi hub, so any help you can offer would be gratefully received.
Hi @simon3030
If you are interested in trying it at £9 PM you will need to apply on the link if you have been selected for an early installation invitation. Try posting on the TV section as this area
is pretty much unvisited by any OCE's.
