Sagecom Fast 5364 firmware trial
Still early days but visually a big improvement and some of the features that were not there like reserved IP in DHCP are there now but still to test.
Biggest thing for me at the moment is that I am still unable to clear the 1500+ pages of errors in the logs which is not helping me identify more about the possible DNS error I have on TalkTalk.
Just spoken to a guy in technical support about the inability of contacting team even after using information in the email they sent, nobody in customer support has heard of the trial. He is going to get back to me with a better way.
My router is detecting the wireless connection of my netbook, but not my iPad.
Can you share email address you received from talk talk to get firmware trial.
Thanks,
Hi, when I try to add the email address I was given for trials it is being removed as invalid. Sorry.
@sanjeanasilva You should not share information like that here, or anywhere for that matter, the details you were sent are confidential to you.
Do you know how I can sign up for the firmware trial to be able use the router which is currently not usable.
@robertkrzysik The firmware trial is now closed. If you have any particular issues with the hub then start your own topic.
I am using latest trial firmware
Only thing missing is a menu to delete log files, but that due in a lalter release
Otherwise, Router throughput has improved, when streaming data
I do not have issues with Broadband dropping. Very stable speeds, and no DLM issues
Wifi is cleaner and connection speeds have increased
Up to now i have found no issues
Use mine for various tablets, Desktops and mobile phones/laptops
Also used with multi room tv.
More than happy with the firmware
Ridiculous , I can't get the latest firmware.
I've spend few hours with technical (brainless) support with no luck.
Time to leave the Talk-Talk and join Virgin.
Thank you very much for this information. Can anyone with the new firmware tell me if can you assign a static IP to each device on the network?
I believe that particular feature has already been slated. Any discussion of trial firmware is precluded by a NDA and participants should refrain from posting on the open forums.
More than aware of the disclosure ruling and don't need to be reminded.
I don't discuss levels or features in software
But i will as per my mail say if something is performing better.
Otherwise the questions revolve around how is it performing or can you do this or that. Disclosure (nda), revolves around specifics on software levels and menu options that pertain to the new software, and something i do not comment on.
OK, if you can find a way of describing any feature which is "performing better" than it was before without anything that might "pertain to the new software" then feel free. 🙂
I would ask to be part of this trial but seeing as I used an offshoot of a well knwon linux distro the first week I got the hub to copy the full config without even logging in then went on to find no less than 19 holes (lan and remote)
Posted on here on my old account to say and was treated like some loony 😛 and told to say exactly how on a public forum. Sent myself potty trying to explain as I am not great with writing and got harassed by a well known member on and off the forum and had to delete my account 😛
NDA means nothing when they dont even listen so. Most talk talk routers have been the same with bad bad software on top of decent hardware.The firmware is a month ahead of researchers at most and the time between updates and the updates do nothing makes it pretty pointless to even discuss the subject.
Ive asked and asked what exactly has been added  every time firmware is updated and just been told its bette. Keep in mind guys ive been with talk talk since 2009 and had most of the routers so its not just this router.
However the hubs backed by SWAN so your connecting to it then to internet so is a lot more secure than most ISP router. The only thing is most exploites now dont happen over the internet and happen over wifi as wifi is useless (WPA3 not even out yet and its already been reverse engineered)  and SWAN only runs between router and network so does not protect your LAN.
Just the way the internet is but you would think after the multiple breeeches talk talk have had they would listen and not just let a non talk talk employee go out his way to make out someone reporting bugs is talking nonsense.
As it stands 3 evil bugs with the hub not counting all the other problems it has and lacking everything. They should be CVE but talk talk threaten court orders anytime anythings posted over at :cve.mitre,
sorry to be negative guys just talk talk do nothing when it comes to cybersecurity and leave it upto the company that router comes from to develope. I even phoned up sagemcom and was screamed at by a french lady cause she did not speak englsih.
Just to add the linux distro I use is called Harry Linux (cause rodney linux just dont sound right and kali linux is already taken 😛 is 50 prefect kali 30 percent backbox and a whole lot of KDE on top. Is so so good for CTF :):)
anyways merry xmas and mind this subject with the firmware has been discussed since the  hub came out and nothing has changed and nothing will 🙂
just noticed my router has had an upgraded ui firmware however 5ghz wifi no longer works and it feels more buggy than it did before 😛
I dont understand how a company so big can be so bad at doing this one thing right......
any explanation? also what is new with this new firmware? apart from it breaking more 😛
oh the log is better now so.........
Hi, Im having the same issues with the new wifi hub, my old super router died and i was offered a new super router or a "superior" wifi hub that is not living up to its name, need static IP, devices not remembered and lack of control, i have been on the chat with them for ages and they seem unwilling to do anything about this?  have any of you guys got anything resolved in relation to this yet?
The lack of control is due to them not wanting over run by dns and other dork tactics. Its because tehy are so big and giving customers a router that can be modded and emulated to a large percentage of routers on the network easy would not be good us all.
However it does seem to be ocked to the extent that things that we change like reserved ip and familiar naming of devices just dont stick 😛 - its like automated so it resets back to original settings. If you can say bit more about problem and what exactly trying to do that cant can try help as will others here.
I was not happy with talk talk for a while and for good reason but most things that can do with other isp routers like gain info and get in just dont work with this hub and atm only 1 greyware  problem that will become something eventually but by that time will be patched and covered hopefully.
Will disclose lil info not that most will understand but will anyways.
Whats this all about
02.02.2019 23:50:32 ERR DNS 0 DNS name resolution failure (wxzzjlhs)
02.02.2019 23:50:32 ERR DNS 0 DNS name resolution failure (ovkmfoqcdqdu)
02.02.2019 23:50:58 ERR DNS 0 DNS name resolution failure (mobile-mail.google.com)
02.02.2019 23:51:26 ERR DNS 0 DNS name resolution failure (mobile-mail.google.com)
02.02.2019 23:53:38 INF WIFI 1 Device <9C:4F:CF:D1:3C:78> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
02.02.2019 23:53:38 INF WIFI 1 A WiFi device <9C:4F:CF:D1:3C:78> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
02.02.2019 23:54:42 ERR DNS 0 DNS name resolution failure (ewfbhtuthzgbbn)
02.02.2019 23:54:42 ERR DNS 0 DNS name resolution failure (wupdelhinheynd)
02.02.2019 23:54:42 ERR DNS 0 DNS name resolution failure (zpawxhh)
02.02.2019 23:54:44 ERR DNS 0 DNS name resolution failure (mobile-mail.google.com)
02.02.2019 23:56:47 INF WIFI 1 Device <9C:4F:CF:D1:3C:78> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
02.02.2019 23:56:47 INF WIFI 1 A WiFi device <9C:4F:CF:D1:3C:78> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
02.02.2019 23:57:21 ERR DNS 0 DNS name resolution failure (cofnwgukwd)
02.02.2019 23:57:21 ERR DNS 0 DNS name resolution failure (nnuxjwgw)
02.02.2019 23:57:21 ERR DNS 0 DNS name resolution failure (szinhsei)
02.02.2019 23:57:24 ERR DNS 0 DNS name resolution failure (mobile-mail.google.com)
02.02.2019 23:59:54 INF WIFI 1 Device <9C:4F:CF:D1:3C:78> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
03.02.2019 00:03:22 INF WIFI 1 A WiFi device <9C:4F:CF:D1:3C:78> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
03.02.2019 00:03:57 ERR DNS 0 DNS name resolution failure (vledxildpms)
03.02.2019 00:03:57 ERR DNS 0 DNS name resolution failure (fxvuloazlwe)
03.02.2019 00:03:57 ERR DNS 0 DNS name resolution failure (hdinzbqrkq)
03.02.2019 00:06:20 INF WIFI 1 Device <C8:02:10:07:34:1E> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
03.02.2019 00:06:29 INF WIFI 1 A WiFi device <C8:02:10:07:34:1E> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
03.02.2019 00:06:57 INF WIFI 1 Device <C8:02:10:07:34:1E> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
03.02.2019 00:14:33 ERR DNS 0 DNS name resolution failure (invalidhost.invalidtld)
03.02.2019 00:31:56 ERR DNS 0 DNS name resolution failure (halwykcvzggdm)
03.02.2019 00:31:56 ERR DNS 0 DNS name resolution failure (wevuvxgcryc)
03.02.2019 00:31:56 ERR DNS 0 DNS name resolution failure (jzvxyuh)
frpm log and constant including some personal details (not posted) Any thoughts? I know what it is but not getting into that 😛  was wanting to message or email talk talk with full log and ask for reason but its so greyware atm and leaking very little data and will only be treated as nothing until its a breech so.
Perhaps its something alien that jumps? if so they should say "some of your data goes towards research to help us improve and we use alienvault as part of our system of protection.
Its not alien vault 😛
Sorry never meant to be negative and is np for me as dont have the hub connected direct to anything personal just youview and its amazing when set up right for the tv side and not one lil dc 🙂 37 days in sync without dc is legit stable and not one lil pixel of tv out of place.
Most dont realise the lenghts talk talk have went to recently in comparison to other ISP and not anything that could be posted and explained. Just hope they keep it up as the dns shuffle/dork will catch up eventually but sagemcom seem to know whats what (hard for me to say) they even have english speaking support now and nice people who at least listen when you say about future breeches that wont be breeches of info more disruption to network.
laters guys take care and thank god for mr robot and GDRP as without that tv show the pwnage would still be going on.
Try changing the TalkTalk DNS servers to say Google’s they are a lot faster, 8.8.8.8 & 8.8.4.4
xxxxxx2600t is the latest release
Hi Will reboot soon and changed to talk talk dns and reset router and
30.10.2019 23:03:03 ERR DNS 0 DNS name resolution failure (nryoxnb)
30.10.2019 23:03:03 ERR DNS 0 DNS name resolution failure (nftanzma)
30.10.2019 23:03:03 ERR DNS 0 DNS name resolution failure (cuwuxgxctvrlf)
30.10.2019 23:05:06 ERR DNS 0 DNS name resolution failure (bwatvmshvdp)
30.10.2019 23:05:06 ERR DNS 0 DNS name resolution failure (jicjnbljgudc)
30.10.2019 23:05:06 ERR DNS 0 DNS name resolution failure (lhwwaybvmi)
30.10.2019 23:07:42 ERR DNS 0 DNS name resolution failure (ttroiter)
30.10.2019 23:11:10 ERR DNS 0 DNS name resolution failure (cmmlzpphgjbk)
30.10.2019 23:11:10 ERR DNS 0 DNS name resolution failure (vhlmhpkil)
30.10.2019 23:11:10 ERR DNS 0 DNS name resolution failure (khtxyaprk)
30.10.2019 23:11:14 ERR DNS 0 DNS name resolution failure (mjrbrmbvjefaq)
30.10.2019 23:11:14 ERR DNS 0 DNS name resolution failure (uxzznzpnwyqrrm)
30.10.2019 23:11:14 ERR DNS 0 DNS name resolution failure (jqzgbndggcpq)
30.10.2019 23:11:28 ERR DNS 0 DNS name resolution failure (mvmlspzuabgogy)
30.10.2019 23:11:28 ERR DNS 0 DNS name resolution failure (auxetjfvviuh)
30.10.2019 23:11:28 ERR DNS 0 DNS name resolution failure (nwwiibgocpd)
30.10.2019 23:13:32 ERR DNS 0 DNS name resolution failure (xytgcjxhcyom)
30.10.2019 23:13:32 ERR DNS 0 DNS name resolution failure (jvjqkilgualt)
30.10.2019 23:13:32 ERR DNS 0 DNS name resolution failure (qtdbkhllat)
30.10.2019 23:14:06 ERR DNS 0 DNS name resolution failure (iebfyuavm)
30.10.2019 23:14:06 ERR DNS 0 DNS name resolution failure (nzlxvaaksbxluj)
30.10.2019 23:14:06 ERR DNS 0 DNS name resolution failure (saptraci)
30.10.2019 23:18:59 ERR DNS 0 DNS name resolution failure (192.168.l.156)
30.10.2019 23:20:33 ERR DNS 0 DNS name resolution failure (oftpcbyisofda)
30.10.2019 23:20:33 ERR DNS 0 DNS name resolution failure (phabrwrljjfskda)
30.10.2019 23:20:33 ERR DNS 0 DNS name resolution failure (dhiqnartsqhdsqu)
30.10.2019 23:22:51 INF WIFI 1 Device <FC:49:2D:08:0B:CE> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
30.10.2019 23:23:27 ERR DNS 0 DNS name resolution failure (qgpxolrjpwu)
30.10.2019 23:23:27 ERR DNS 0 DNS name resolution failure (eshwrlwscvrzf)
30.10.2019 23:23:27 ERR DNS 0 DNS name resolution failure (mbquwrecnjtspkj)
30.10.2019 23:24:38 ERR DNS 0 DNS name resolution failure (phexonhumk)
30.10.2019 23:24:38 ERR DNS 0 DNS name resolution failure (ihwtolrkmpiifa)
30.10.2019 23:24:39 ERR DNS 0 DNS name resolution failure (ddthepm)
30.10.2019 23:24:53 ERR DNS 0 DNS name resolution failure (sayjioqectj)
30.10.2019 23:24:53 ERR DNS 0 DNS name resolution failure (nikmzfkll)
30.10.2019 23:24:53 ERR DNS 0 DNS name resolution failure (comdmpbwyqhgwh)
30.10.2019 23:25:02 ERR DNS 0 DNS name resolution failure (192.168.l.156)
30.10.2019 23:25:25 INF WIFI 1 A WiFi device <FC:49:2D:08:0B:CE> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
30.10.2019 23:27:33 ERR DNS 0 DNS name resolution failure (http192.168.l.156)
30.10.2019 23:30:35 ERR DNS 0 DNS name resolution failure (ttroiter)
30.10.2019 23:31:34 ERR DNS 0 DNS name resolution failure (avdogjdfeheptyt)
30.10.2019 23:31:34 ERR DNS 0 DNS name resolution failure (jnzjqqrdev)
30.10.2019 23:31:34 ERR DNS 0 DNS name resolution failure (wujkwrzxjmnvdp)
30.10.2019 23:35:05 ERR DNS 0 DNS name resolution failure (bphejvhx)
30.10.2019 23:35:05 ERR DNS 0 DNS name resolution failure (apumvbz)
30.10.2019 23:35:05 ERR DNS 0 DNS name resolution failure (ekuojabvxjjgqi)
30.10.2019 23:35:21 ERR DNS 0 DNS name resolution failure (192.168.l.156)
31.10.2019 00:20:08 INF LETH 0 A device has been disconnected from an Ethernet port (3)
31.10.2019 00:20:14 INF LETH 0 An Ethernet port is now connected (3/100/FULL)
31.10.2019 00:25:51 ERR DNS 0 DNS name resolution failure (stats.qalabs.symantec.com)
31.10.2019 00:26:12 ERR DNS 0 DNS name resolution failure (stats.qalabs.symantec.com)
31.10.2019 00:50:21 ERR DNS 0 DNS name resolution failure (frca1lbip.francecentral.cloudapp.azure.com)
31.10.2019 01:04:23 INF LETH 0 A device has been disconnected from an Ethernet port (4)
I mean I know its nothing bad just its like that last time the dns beebop was happen and kept post to say and ask why and told "its just the nature of ADSL" 😛
I mean of coarse its just a bug of sorts and will be very common to talk talk routers just the whole
(cmmlzpphgjbk)
(vhlmhpkil)
khtxyaprk)
(mjrbrmbvjefaq)
 (uxzznzpnwyqrrm)
(jqzgbndggcpq)
and this just few entry. Of coarse it can be explained just it being a bug its random letters must be random bug so not explainable. Maybe not talk talk end and browser or other extension etc.
Just seems so familiar but google and internet have not seen it.
Oh right its on friends talk talk router also and as said am sure its nothing, until its something then its a data breech via random dns.
wait wait, before people start jump on the "talk talk have been smashed" waggon
https://unix.stackexchange.com/questions/363512/chrome-dns-requests-with-random-dns-names-malware
i use opera and its something to do with either ublock or https everywhere I think (or its talk talk being hijack by a guy who then sells the details online and gets caught 😛 - cause that is what you would do once youn went to trouble of gaining access to ISP records.
sorry just I find it hard to believe that that guy did much more than receive an email with customer details then sell them on, however ive been wrong 9 million times before so 🙂
but yup guys ty for the firmware update and being honest about the talk talk hub guys - 42 days in sync is very impressive and only unsync when I restart it so ty.
mum just die guys and not watch the youview as was for her but am keep it as its decent to have an cheaper than sky.
