Static Route
1 REPLY 1
steven richardson
I need to add static routes to 3 internal different subnets that I have setup behind a Cisco ASA that I have connected to the TAKTAK WiFi Hub, currently the default is on the TT router and will be dropped, When I add the routes it does show on the routing table but once I hit apply it disappears, is this a bug with the router I have
Serial NumberHardware VersionSoftware Version
N7183244N003677
FAST5364 3.00
SG4K10002808t
Please could you give me the settings I may need to set up a Cisco router in place of the TT router if I cannot add static routes to this
Hola
hosay299
@steven richardson please post in the help area this is a not Support area
As it is designed for people on trail of parts of talk talk system and kit.
Hope that help Regards Joe
