Showing results forΒ
ShowΒ Β onlyΒ  | would you rather see results forΒ
Did you mean:Β
TV Trials
11 REPLIES 11
Was great to be accepted to take part, downloaded app as required then told to click link to join discussion group. Access denied! πŸ€”πŸ€”πŸ€”
That sounds about right for Talktalk. I've joined (eventually) in the vain hope they listen to what customers really think. We have to report set top box issues. My recent replacement box is as unreliable as the previous one so they'll be getting daily error reports from me. Don't know how the scout app gets invoked.
If nothing's changed in 24 hours I'm just going to uninstall the app and leave the elite private group to it lol πŸ˜‚
Hi Childermass2112
pleaes wait or e-mail the trials team direct on there e-mail address.
As this problem u have with the app could taje a week or 2 to be fixed.
As it could be they have to add u their end which might not have been done for some reason.
This fourm for the trails team is not full looked at by them so i would e-mail them direct and wait and see what they say to ur issue u have.
As i have had similer issues in past and was they have not changed things there end or one deparment had not told them what they had changed on the main system like when i went on t fibire bb they had changed my tv setting on the main system but trails team did not know they had done that so i could not get the up-dates they sent out.
they got it sorted in the end which means it just needs some time to let them work it out.
this fourm is not a 24 / 7 /365 day support.
Hope that help Regards Joe
I have joined and have no idea what to do.
Can anyone help me?
Cheers
Andy
I can't use the Dscout app as my phone is too old. Runs Android 4. When I queried it, there was a minimum version of 5. something that was required. might be worth checking as the app installed but would not work.
You also can't run it on a tablet as it's a phone app only. My tablet version would have been OK.
You will receive e-mails asking you to accept "missions" in Dscout and you then log issues. I respond via the e-mails that then get added to the Dscout profile.
I'm waiting on a new phone so hopefully I'll be back up and running soon.
@fr8ys So in order to be involved in TalkTalkTV trials you have to have an Android phone/tablet of recent vintage? So iOS, Apple devices, PCs etc. are not included?
Hi fr8ys & ferguson
I installed dscout on my ipad 2 mini yesterday and works ok.
Gromit
Cheers all. I was having trouble on a Samsung galaxy, I cleared cache, uninstall/reinstall and its all good now 🀞
TT would like you too. However you can reply to emails  with are effectively sent from your dscout account so any reply is added to your profile.
My one issue with dscout recording is you don't know if others are suffering the same issues as you.
Great news.  I've been able to download the TalkTalk TV app and am looking around it now.
Will let you know how it goes.
Andyk11
U get e-mails that are sent from the discount app thing and u can reply to it or they have a link in which takes u to a survey site
