Youview/talktalk TV box DN372T Failed Recordings etc
4 REPLIES 4
moxy51
Funny things are happening with TV box-at the moment recordings fail-if i press record while watching live tv recording comes up on the screen but the planner says recording failed - if i set record from the guide it shows record is set-but later in the planner it says recording failed,also the remote just suddenly stops working & sometimes playing back from the guide a fews days ago stops working a reboot puts some problems right but sofar the recording facility has not come back on working-any ideas?
P.S. Software Version:72.47.159
UPDATE 11.30am Saturday 19th
I have just tried Maintenance reset -unfortunately the recording facility is still not working.
ChrisFord
Enlightened One
As this post refers to trial firmware I believe that it should be posted in the TV trials closed group.
hosay299
@ChrisFord @moxy51 which is this the closed group????
Hope that help Regards Joe
ChrisFord
Enlightened One
This is the area of the community forum that I am thinking of:-
TalkTalk Trials / TV Trials
which is a closed group for triallists.
Lynnes
Trials Manager
Hi Joe,  You are a member of the closed TV Trial forum described below. Thanks, Lynne.
To feedback or report an issue send an email to talktalktrials@talktalkplc.com
