AVM FRITZ!Box 7590 on TalkTalk fibre
Dodgydrains
Whizz Kid
Message 7 of 7
This may be a silly question...
Has anyone used AVM 7590 before, or another modem/router from this AVM?  Is this product any good with TalkTalk fibre?
https://www.amazon.co.uk/AVM-FRITZ-Box-Integrated-Supervectoring/dp/B074G5Z1PQ/ref=sr_1_1?ie=UTF8&qi...
Are there any settings needed to get it working on TalkTalk fibre?
6 REPLIES 6
Message 1 of 7
@ferguson
The post before mine helped but there is no Bridged Routed encapsulation option in the 7530 internet setup screen.  I will look for your suggestions later.  Thanks.
Message 2 of 7
@Bob Owen TT staff can’t help with non-TT equipment. You need auto DHCP and/or IPoE or similar. Start your own topic if you are still stuck. Did the post immediately before yours not help?
Message 3 of 7
I have a FritzBox 7530 and trying to follow the advice on a number of TT community threads on how to connect it, so far to no avail.
I am using the user name of number@tt and the password of 123456 because the 7530 will not do anything without a username and password and the above were suggested as viable.
I am using VLAN ID of 101
I am using VPI of 0 and VC! of 38
I can choose from PPPoE, PPPoA/LLC or PPPoa/VC-MUX for encapsulation but whichever I choose, and most threads suggest PPPoe is the correct one, I still don't get connected.
A definitive answer from a member of TT staff would be appreciated.
Message 4 of 7
AVM Fritz!Box 7530 (OS: 7.10) works very well with TalkTalk: Here are my settings:
Internet>Account Information>Internet connection
Internet service provider: TalkTalk
Connect via: Connection to a DSL line
Account Information: Is account information required? No.
Connection Settings:
VLAN Settings: Use VLAN for internet access: Yes- VLAN-ID: 101
DSL ATM Settings: VPI 0, VCI 38.
Encapsulation:
Bridged (Routed Bridge Encapsulation): Yes
Obtain the IO adress automatically (DHCP): Yes
jamieburchell
Super Duper Contributor
Message 5 of 7
Did you go for the 7590? I've been using a 7490 with TT for years.
Message 6 of 7
Hi Dodgydrains,
I've included a Help Article below 🙂
Set up a non-TalkTalk router
