Community Wifi Idea - Need Help!
Haynzy
Message 2 of 2
I am running a small cafe and would like to use the Wifi to attract customers. Is it possible to change the password for the WiFi without bumping off certain devices. For instance; my POS system, phones and radio use the Wifi for orders so we would like to know if there's any way of chaning the password daily without bumping these devices that are vital for our operation. It would take the pain of having to sign in each device manually when we change the password.
I just thought it'd be a workaround since the routers aren't capable of Guest Wifi profiles.
Thanks!
1 REPLY 1
Message 1 of 2
I think you would do better to look for a business broadband provider, you would almost certainly be in breach of your terms of service if you tried this on a TalkTalk residential service.
https://www.talktalkbusiness.co.uk/
