How to connect DCP-375CW Brother Printer by wireless
Petergeegee
Message 2 of 2
I am trying to connect my printer but I am told by Talk Talk it is not supported.
Can any one help?
1 REPLY 1
Message 1 of 2
Which router are you trying to connect it to? Have you managed to set it up wirelessly before?Have you checked the Brother support page to check that all downloads are up to date? You will also find all relevant instruction documentation there. You will probably need to connect via USB in the first instance though.
https://support.brother.com/g/b/producttop.aspx?c=gb&lang=en&prod=dcp375cw_all
