how do I use talk2go on other wifi networks other than my home one?
MAldous
Message 6 of 6
I've set up Talk2go fine on my phone and can use it fine on my home network When I try to use on third part network (the cloud for example),, I can conect bowser and other apps but Talk2go will not conect and I can nor use it
5 REPLIES 5
Message 1 of 6
Hi Maldous,
No it should just transition between the two.
Cheers
Message 2 of 6
Thanks OCE_Mark.
I will wait a little while before doing that to see if anyone else reports a simliar problem. It is possible me doing something real silly or not doing something.
Darft as it may sound when you change networks do you need to close Talk2go down and then restart it?
Message 3 of 6
hi MAldous,
Theres no specific reason it shouldnt work, unless as spike has suggested VOIP is blocked.
You may want to send an email to the app developers using the email address on the play store. They will be able to investigate further into this for you.
Cheers
Message 4 of 6
@spike wrote:
some public networks will block voip (voice over internet protocol)
I could understand that an accept it, BUT I cannot conect to any other net work even other TalkTalk users.
spike
Whizz Kid
Message 5 of 6
