Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
HTML checker rejects posts
Gondola
Hi TalkTalk web designers.
 Just tried to centre align this text using the align centre button above.
Feeling rejected.
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
 Gondola - I'm a TVPlus customer *
Gondola
Hi @StephenF
The HTML checker still rejects the use of the centre align button. Is a fix included in the next batch?
StephenF
Community Manager
Strange, just tested and didnt see the error, maybe its permissions let me take a look.
EDIT: Permissions are ok, what browser is this happening in, and is it on every post?
Gondola
Hi @StephenF
Firefox 51.01 under Windows 10. Every post.
This line was centred also.
Centre Align FailureCentre Align Failure
How did you get your text centre aligned ok?
Gondola
and this one with Chrome under Windows 10.
Left align.
Right align.
Centre align.
Chrome Alignment FailureChrome Alignment Failure
StephenF
Community Manager
hey,
Thanks for this, I've not been able to replicate but its clearly an error. All users have the ability to add simple HTML to their posts and all items in the editor should be acceptable.
I've raised a case with our platform vendors to investigate further.
Gondola
Hi @StephenF
The HTML5 code produced by your post and that produced for mine by the editor icons, above, is identical.
The checker appears HTML5 compliant (it rejects the HTML 4.01 center command for example) so although the error message says the code is not valid I would say the generated code is valid and it's not being allowed for another reason, like the level of permissions, such as you suggested.
StephenF
Community Manager
Looks like this could be a bug as just had confirmation this should be possible, will keep you posted.
StephenF
Community Manager
Hey @Gondola,
Platform vendor have confirmed this is a defect and will be investigated further to find a fix, however, i dont have a timescale, however, i do have a workaround, if you use the html tab you can use the following code which should be valid.
<center>Some text here</center>
Let me know if this doesn't work for you.
Gondola
paragraph left
paragraph center
paragraph right
Yes, that seems to work fine! Good work around!
Thanks!
left
center
right
<p align="left">paragraph left</p>
<p align="center">paragraph center</p>
<p align="right">paragraph right</p>
<p align="left">Yes, that seems to work fine! Good work around!</p>
<p>&nbsp;</p>
<center>Thanks!</center>
<div align="left">left</div>
<div align="center">center</div>
<div align="right">right</div>
StephenF
Community Manager
