Here's what to do if your Wi-Fi connection keeps cutting out.
If your Wi-Fi signal keeps dropping on one device, go into the device's Wi-Fi settings and 'forget' your network. Then connect to your network again. If this doesn't help, or it's happening on all of your devices, follow the checks below.
Your Wi-Fi signal comes from the front of your router, so make sure it's upright and facing into the room. Try putting your router in an elevated position on a table or shelf, and make sure it’s not blocked by any furniture or books. This way, your router can give out a clear, uninterrupted signal.
Electrical appliances like bluetooth speakers, cordless phones, baby monitors and even remote controlled toys can disrupt your Wi-Fi signals. You should switch these off when they're near your router or move them away if you can.
If your Wi-Fi only drops when you're far away from your router, our Wi-Fi Extender Kit can help by making your signal go further.
If you’re still having issues, turn your router off and switch it back on after 20 minutes. A software update may have gotten stuck and a quick reset will force it through. You shouldn't restart your router more than twice within 24 hours.
Our experts are here to help, select one of the following contact options:
View & pay your bills & keep tabs on your usage.
Recommend UFO to your friends & family to save money
Checking availability...
To help us deal with your query quickly, please confirm the following information when you write to us. We will aim to respond in writing to your query in 10 days.
- Your full name
- Your TalkTalk Phone or mobile number
- Your Signature
TalkTalk Correspondence Dept
PO Box 675
Salford
M5 0NL
All letters will be sent to the primary billing address unless stated otherwise. Please also include the best way to contact you about your query, such as your contact phone number or contact address.
For help with your UFO service call: 0800 230 0272
To place an order for UFO call 0800 230 0219 or visit talktalk.co.uk/ufo
Make sure you have your account details to hand when you call.
Calls are free from your TalkTalk phone, our customer services team are available 9am-6pm, Monday to Friday. If you’re deaf, hard of hearing or speech-impaired, the Text Relay Service can be used to help you contact us, simply dial 18001 followed by 0800 230 0219
