How UFO is installed
No ratings
To connect your home to UFO, our expert engineers will either go underground by digging a small trench across your garden or drive, or overhead using existing Openreach poles. If they go underground they'll agree the route with you and put everything back to how it was when they've finished.
We've introduced some precautionary measures for our UFO engineers in response to the outbreak of COVID-19 which may affect your installation appointment. More information.
We'll do everything in one appointment that usually takes around 2 hours and we'll make sure you're up and running with Ultrafast broadband on all of your devices before we leave.
Here are some things to remember before your installation day:
  • If you don't own your home, it's important that you check with your landlord or freeholder to make sure we're ok to go ahead with the installation.
  • You can rearrange your appointment up to 12pm the working day before in My Account or by calling us on 0800 230 0272.
  • It's a good idea to block out an entire morning or afternoon for your appointment because installation times can vary.
  • Your Wi-Fi Hub and UFO Homeport will need to be plugged into two sockets near to each other and should be in the room where you use your internet the most.
To see exactly how we install UFO, watch our video below.
Need to speak to our team?
Our experts are here to help, select one of the following contact options:
To help us deal with your query quickly, please confirm the following information when you write to us. We will aim to respond in writing to your query in 10 days.
- Your full name
- Your TalkTalk Phone or mobile number
- Your Signature
TalkTalk Correspondence Dept
PO Box 675
Salford
M5 0NL
All letters will be sent to the primary billing address unless stated otherwise. Please also include the best way to contact you about your query, such as your contact phone number or contact address.
For help with your UFO service call: 0800 230 0272
To place an order for UFO call 0800 230 0219 or visit talktalk.co.uk/ufo
Make sure you have your account details to hand when you call.
Calls are free from your TalkTalk phone, our customer services team are available 9am-6pm, Monday to Friday. If you’re deaf, hard of hearing or speech-impaired, the Text Relay Service can be used to help you contact us, simply dial 18001 followed by 0800 230 0219
