Set up your router for UFO
No ratings
If you've got UFO, you'll need to set up your router a little differently. Choose your router from the options below to get started.
  1. Plug the UFO Home Port power cable into the wall socket and switch it on.
  2. The power light and PON light on the UFO Home Port will turn green.
  3. Open the lower panel on the UFO Home Port.
  4. Plug one end of the Ethernet cable into the LAN port.
  5. Plug the other end into the WAN port on the back of your Wi-Fi hub.
  6. Now plug the power cable into your Wi-Fi Hub and wall socket and switch it on.
  7. Push the power button on the back of your Wi-Fi Hub.
  8. The LED on the front will turn white when it’s on and connected.
  1. Plug the UFO Home Port into the wall socket and switch it on.
  4. Plug one end of the Ethernet cable into the LAN port on the Home Port.
  5. Plug the other end into the red WAN port on the back of the Super Router.
  6. Plug the Super Router into the wall socket and switch it on.
  7. Push the power button on your Super Router.
Need to speak to our team?
Our experts are here to help, select one of the following contact options:
To help us deal with your query quickly, please confirm the following information when you write to us. We will aim to respond in writing to your query in 10 days.
- Your full name
- Your TalkTalk Phone or mobile number
- Your Signature
TalkTalk Correspondence Dept
PO Box 675
Salford
M5 0NL
All letters will be sent to the primary billing address unless stated otherwise. Please also include the best way to contact you about your query, such as your contact phone number or contact address.
For help with your UFO service call: 0800 230 0272
To place an order for UFO call 0800 230 0219 or visit talktalk.co.uk/ufo
Make sure you have your account details to hand when you call.
Calls are free from your TalkTalk phone, our customer services team are available 9am-6pm, Monday to Friday. If you’re deaf, hard of hearing or speech-impaired, the Text Relay Service can be used to help you contact us, simply dial 18001 followed by 0800 230 0219
