UFO Homeport lights guide
No ratings
The lights on your UFO Homeport can tell you what's wrong if you're having problems with your connection.
Light Status Description
1 - TEL Green      Your phone service is registered on the UFO network.
Flashing green A telephone call is taking place.
Off Your phone service isn't registered on the network.
2 - LAN Green Data is being sent through the Ethernet cable connected to your Homeport and Super Router.
Off The Ethernet cable may have become loose. Check that it's still plugged securely into the red WAN port on your Super Router.
3 - LOS Green You're getting a successful UFO connection.
Red You're not getting a connection.
4 - PON Off Your Homeport is registered on the UFO network.
Flashing green Your Homeport isn't registered correctly.
5 - POWER Green Your Homeport is switched on.
Off Your Homeport isn't getting any power. Make sure the power supply is plugged into a wall socket and switched on.
6 - STATUS Green Your Homeport's battery is charging.
Off Your Homeport may have a faulty battery.
7 - FAULT Green  Your Homeport is working normally.
Red Your Homeport may have a faulty battery.
8 - CHG/DISCHG Off Your Homeport is working normally.
Amber Your Homeport's battery is charging.
Need to speak to our team?
Our experts are here to help, select one of the following contact options:
To help us deal with your query quickly, please confirm the following information when you write to us. We will aim to respond in writing to your query in 10 days.
- Your full name
- Your TalkTalk Phone or mobile number
- Your Signature
TalkTalk Correspondence Dept
PO Box 675
Salford
M5 0NL
All letters will be sent to the primary billing address unless stated otherwise. Please also include the best way to contact you about your query, such as your contact phone number or contact address.
For help with your UFO service call: 0800 230 0272
To place an order for UFO call 0800 230 0219 or visit talktalk.co.uk/ufo
Make sure you have your account details to hand when you call.
Calls are free from your TalkTalk phone, our customer services team are available 9am-6pm, Monday to Friday. If you’re deaf, hard of hearing or speech-impaired, the Text Relay Service can be used to help you contact us, simply dial 18001 followed by 0800 230 0219
