Covid issues during installation?
ukjbra1
Message 3 of 3
Hi I was told by my current provider that engineers should not be entering the home due to covid and that any appointments made would be cancelled. Is this correct? I will need a full installation as joining from virgin?
Andrew7856
Whizz Kid
Message 1 of 3
@ukjbra1
Did Virgin tell you this?  If so then I believe its a way of making you stay with them longer, and not migrating to TT-UFO.  Funny how Virgin still offer home visits for installation works but they want you to think TT-UFO should not be allowed.
The TT-UFO is pretty safe, and contact free - the installer worn a face mask, and I cleaned down any area he had touched as I would have done naturally.    Rest of the team stayed outside, and you are more at risk from your Postie than the installers.
Arne-TalkTalk
Message 2 of 3
Hi @ukjbra1
Thanks for your post.
Engineers will do all they can to activate a service remotely. What service are you ordering if it s FTTC and you have a BT socket already in the property you should be OK.  If there is no socket it may be delayed.
Hope that helps.
