I have a red fault light on my home port. How do I address this please?
Joandmart
Appeared yesterday after I turned socket off. Everything is working ok but red light is still on.
Florencio
1.Check whether the Fiber router is switched on. If you are using a secondary router for Wi-Fi, check if it is powered on.
2.Check whether “LOS indicator” on the Fiber Router is glowing red. The RED LOS light indicates some ongoing network problem.
OCE_Michelle
Hi Joandmart,
I'm sorry to hear this. Have you contacted our UFO Team directly so they can look into this for you?
  UFO Support Team
