Ring access
wbs4975
Message 16 of 16
I've recently had UFO installed, with a Fast5364 router, but it's caused my Ring to stop working because it won't work with a 5Ghz band. How can I get the Ring to see the 2.4Ghz band?
15 REPLIES 15
Message 1 of 16
Ok thank you for the update.
Thanks 🙂
Message 2 of 16
I am, but it's ok, problem is fixed.
I rang Ring technical support and they eventually got the doorbell working after a router reset.
Message 3 of 16
OK thanks, could I just ask if you are currently posting from you TalkTalk connection?
Message 4 of 16
Ok, have done so.
Message 5 of 16
Hi wbs4975,
Could you add your name and account number to your community profile and let me know when you done this. I'll then see if I can disable wifi optimisation
Message 6 of 16
I'll try to find out if I can disable wifi optimisation and get back to you
Message 7 of 16
Hi wbs4975,
If other customers can help with your query that's fine it just that we (the Community Team) currently don't have visibility of Future fibre customers on our systems and so can't offer the level of support that we do to our other customer, I'm sorry about this.
Message 8 of 16
I have offered to help you with this, but it is not really much point unless WiFi Optimisation is disabled.
Message 9 of 16
Yeah, I get told that they don't provide technical support for non-Talktalk products, which is why I posted on the forums for perhaps some advice from others. So.. do I post on another sub-forum?
Message 10 of 16
OK thanks, I'm sorry but you'll really need to speak to our Future Fibre support team, they should be able to help, there are contact details here
Message 11 of 16
Fibre 150 - sorry, thought they were the same thing. Still need the assistance though! 🙂
Message 12 of 16
Hi wbs4975,
Just to confirm, do you have UFO or our Future Fibre product?
Message 13 of 16
I don’t have a home phone number any more. The line was disconnected just a few days ago, presumably at the start of my billing cycle for the Fibre150?
Message 14 of 16
we can disable optimisation for the customer, if they can update their 'Community Profile' with their home phone number.
Message 15 of 16
The first thing is to log into the router & make sure that the 2.4GHz band is enabled. This can be found by clicking on "See WiFi Settings".
Next is to ask TalkTalk in your reply to disable their remote diagnostic utility called "Wi-Fi Optimisation" on your router. This can change WiFi settings in your router without your knowledge.
Once this has been disabled, I can offer a lot more help if you want it?
