on 20-05-2022 10:10 PM
about 3/4 weeks ago some event happened (firmware 'update') which has caused my router to prevent access to XBox Live games (specifically Minecraft and FIFA22) as well as preventing calls via WhatsApp. Everything else has been eliminated (basically by replacing the router) or by reducing the firewall setting template from high to medium on the router the problem goes away. This is a laughable solution looking at what inbound traffic is blocked by the medium template (NetBIOS only). I want my router back to the firmware it had before the event (firmware update) so I can use it securely whilst being able to use my apps. I have been round in circles with support and it is clear on these forums that there is a known solution, but knowledge of it isn't widespread in TT support and it isn't described in the forums.
on 09-06-2022 05:51 AM
Thanks for confirming this and I'm glad to hear that this is now working ok. I'm just sending you a Community Survey via PM.
on 08-06-2022 05:20 PM
Thanks. Early days but it appears the downgrade has fixed the problem without having to reduce the firewall security settings. I assume the upgrade in firmware was designed to fix something else however since I don't know the purpose, I prefer it at the previous version where it works as expected. Thanks again.
on 08-06-2022 04:07 PM
OK thanks. I've started the firmware update, it can take up to 20 minutes, please don't switch off your router
on 08-06-2022 03:39 PM
2675
on 08-06-2022 03:37 PM
could you post the last 4 digits of the router serial number and we'll roll your firmware back
on 08-06-2022 03:02 PM
Hi, can you downgrade the firmware immediately as requested please.
on 06-06-2022 10:21 AM
Hi scsmedia,
Sorry for the delay, I've asked our Product Team for an update, I'll let you know when I receive one.
on 04-06-2022 07:46 PM
Staff will be back from Monday, @scsmedia.
I'll flag this up again for their attention.
on 04-06-2022 07:19 PM
Hi, time is up for investigating now. Please revert the firmware of the router to what it was at 2nd April 2022. I don't want to see this at SG4K100136 any more. I've had to suffer all of half term with kids not being able to use the XBox.
on 30-05-2022 07:26 AM
They are investigating at the moment and we're just waiting to hear back from the team.
on 29-05-2022 09:12 PM
Now they know, when can I expect it fixed please? Thanks. Chris
on 23-05-2022 02:39 PM
OK thanks, I'll let them know
on 23-05-2022 02:37 PM
There is one port forward rule and a Dynamic DNS configured. Didn't work with these unconfigured either (i.e. vanilla factory reset with FW set to high.
on 23-05-2022 02:22 PM
Our product team have asked if you've made any other changes to the router settings, other than changing the firewall to high?
on 23-05-2022 02:05 PM
OK thanks
on 23-05-2022 02:03 PM
done 🙂
on 23-05-2022 01:55 PM
Hi scsmedia,
Could you add your landline telephone number to your community profile
on 23-05-2022 10:39 AM
OK thanks. I'll pass this over to our Product team and ask them to take a look, I'll let you know when I receive an update
on 23-05-2022 10:36 AM
On the previous version it was set to high (I have a backup of the config) but I don't know if it was default as it has been like that for over two years. Point is the config worked for two years and now it doesn't.
on 23-05-2022 10:28 AM
And on the previous firmware version it was set to medium by default and you set it to high?
