Setting up a raspberrypi server
toiletrage
UFO Customer
UFO Customer
Message 4 of 4
I would like to set up a server on a raspberrypi that can be accessed from anywhere.
How would I set that up in the router?
Cheers
3 REPLIES 3
Message 1 of 4
Hi toiletrage
It depends on what you actually want to serve on your PI?
For the basics, you would be best to set a static local IP on the PI that is away from the DHCP pool on your router.
Personally, I set my router to DHCP from 192.168.1.150 onwards, therefore I have 51 free local IP's I can assign for devices I want to be static.
Then simply forward the ports you need for your server on your router to the static local IP of your PI.
Boswell
Message 2 of 4
Hi toiletrage,
Checked into it. Depending on how you're setting up the server, you'll need to enable port forwarding on the HG635 router.
you may find the following link helpful for setting up the port forwarding: https://community.talktalk.co.uk/eigde79682/attachments/eigde79682/32/14869/1/TalkTalkSuperRouterPor...
Kind Regards,
Farhan.
farhanazad85
UFO Customer
UFO Customer
Message 3 of 4
Hi toiletrage,
Interesting one, I've never setup a server on the raspberry pi myself.
Let me look into it a bit and see how we can go about it.
I'll get back soon.
Kind Regards,
Farhan.
