Settings for POP3 SMTP when using 3 mobile
4 REPLIES 4
Geluk
Despite extensive searching I've not been able to find smtp settings when connecting to onetel servers via a 3 mobile router.
  I can receive e mails fine obviously, but can't send.
Anyone here a user of this happen to have a
clue as to settings that'll work?
Assistance appreciated; 3's website, disappointingly of zero use on this!
Gondola
Hi Geluk
Here are the settings to use.
Account Type  POP3
Username username@onetel.com
Password Yes
Incoming host name pop.talktalk.net
Incoming Port 995
Incoming Security Use SSL
Outgoing host name smtp.talktalk.net
Outgoing Port 587
Outgoing Security Use SSL (Use StartTLS if available on the app)
Authentication method Password
Remember that the Username is the full onetel email address.
Let us know if Mail is now working ok. If asked to accept a certificate the response is Yes / Accept.
GondolaVolunteer 2017-2021
 Give Likes below to appreciate my help . . . and to help others Best Answer
Geluk
Great!
Other forums were saying you must use 3's SMTP settings, but it don't work!
ie
smtp-mbb.three.co.uk
Gondola
This is not just any other forum. This is the TalkTalk Community Forum.
The important thing is that you should be able to access your onetel mail messages via any supported device.
Are you still a TalkTalk Consumer customer for home broadband or are you going to subscribe to MailPlus? About TalkTalk Mail Plus
OCE_Ady
Hi Geluk, it's great to see that Gondola has got this sorted for you.
Ady
