Sonicwall NetExtender VPN performance
j4brz
Message 13 of 13
Hi I’m having poor performance connecting to my office via Sonicwall NetExtender VPN. This used to work OK using Sonicwall global VPN but my company no longer uses this as they wanted to use a VPN with SSL.
Speed wise I am currently seeing 11ms ping, 36Mbps down, 8.5up at home. This was sufficient with the previous VPN.
I get bad latency meaning I can’t control my CAD model due to the delay between moving the mouse and something happening.
Other than this Forum how the heck do you get hold of support these days?
12 REPLIES 12
Message 1 of 13
Hi j4brz
No problem, please let us know how you get on.
Message 2 of 13
Thanks Debbie
Message 3 of 13
Hi j4brz
Message 4 of 13
Hi Debbie,
It’s worth trying assuming nothing can be done with the current setup.
Message 5 of 13
Hi j4brz
Would you like me to send a different make and model of router for testing?
murren wilson
Message 6 of 13
how to claim free gift
Message 7 of 13
Ethernet or Wifi is same result.
Message 8 of 13
Hi j4brz
Is this happening over a wired connection too or are you only using wireless?
Message 9 of 13
Hi Debbie,
Yes this router was no problem with the previous VPN. It is working okay for normal use.
The new one uses SSL but works fine with my laptop on a different network (albeit a faster one). When connecting to my office CAD PC I struggle to manipulate the model due to the graphical latency. Sometimes the screen will freeze for a few seconds making it impossible to control the mouse.
Message 10 of 13
Hi j4brz
I've checked and your router should work ok with VPN.
Are you only experiencing an issue with the connection when using VPN?
Message 11 of 13
Done
Message 12 of 13
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
