network connector red light on ufo broadband
steve-e
Message 5 of 5
I've bought a talk talk network connector to connect my tv up to the internet via an ethernet cable as my main telly is a distance from my router and i'd like the connection to be stronger.  The 'home' socket is connected in the next wall socket to the router and the 'away' socket is in my garden room beneath the TV.  Of the three lights the central one is rapidly flashing red, the ones either side are both green although the one on the right flashes intermittently.
when i tell the telly to connect to the wired lan it will connect, but the connection is really slow and actually works better through the wifi.
I've tried re-pairing the two connectors but it doesn't change the situation.
can someone please help?
4 REPLIES 4
Chris-TalkTalk
Message 1 of 5
Hi steve-e,
How are you getting on, are you still experiencing problems?
Doris514
Message 2 of 5
Your Optical Network Terminator (ONT) has a number of status lights. Its PowerDSL and LAN1 lights should all glow a steady green. If any light is flashing or switched off, select the option which describes its status:
Message 3 of 5
Hi steve-e
Sorry for the delay.
Are they both connected on the same electrical circuit?
Message 4 of 5
This indicates either the two units cannot connect to each other for some reason or a fault in your electrical wiring.
I suspect it is the former because probably your electrics in your house are not compatible with PLAs. Is the garden room on a different electrical ring circuit? These units need normally to be on the same electrical circuit.
