Callsafe
11 REPLIES 11
toiletrage
UFO Customer
Is it possible to have Callsafe with Ultra Fibre Optic Broadband?
OCE_Arne
Hi toiletrage
Unfortunately as far as I know its not compatible with UFO lines , I would suggest contacting the UFO team on the number you have been given to verify that information.
toiletrage
UFO Customer
It is impossible to contact the UFO team as the number provided goes to General support and the number General support has is the same.
OCE_Arne
You will need to ask to be transferred to the correct team.
toiletrage
UFO Customer
I did ask to be transferred to the correct team but the number they tried didn't work. The UFO team number doesn't work.
OCE_Arne
Hi toiletrage
The UFO help page  shows that call safe is actually compatible, but only the UFO team can activate it for you.
Try the Live chat option at the bottom of the page.
Sorry for any confusion.
LindaNess
Short answer NO. I have had TalkTalk UFO for over four years and complained so many times and now told that UFO and CallSafe will never be compatible, even though according to my account and the advertising it is so.
LindaNess
CallSafe is not compatible with UFO and although it may get switched on, it does not work and I am told by the UFO team that it never will.
OCE_Arne
Thanks LindaNess
I will see if I can find some clarification.
LindaNess
Thanks, will you let me know what you find please.  When I have contacted TalkTalk, I am told that CallSafe is switched on, or that they will switch it on.  It is only when speaking to the dedicated UFO team, that I get to know that CallSafe is not compatible and almost certainly I will never get CallSafe or an equivalent.
LindaNess
If you go on the Facebook, dedicated page for TalkTalk UFO, send them a message and they soon respond.  I am in York, where we have had UFO for over four years and they have their own FB page.
OCE_Arne
Hi @toiletrage
It has been confirmed that Callsafe is not compatible with UFO lines
