Poor download speeds!!!
ANSWERED
8 REPLIES 8
BenParkinson26
Sightseer
Could anyone please suggest a way to fix the below? I have spoken to talktalk multiple times over the past couple of weeks about this who have assured me that fixes have been made to the hub to sort this out but still no change! Despite taking dates on two occasions for an engineer to visit still nothing has been booked, so I am hoping there might be a way I can sort this myself. Any help appreciated. Ben.
Can you try a wired test and see how that compares?
peteb99
I think he is already doing a wired test Ferguson as he has got over 900mbps upload on one of the screen shots.   Only Wifi 6 would get anywhere near that.
They look very much like screenshots from a mobile device to me, perhaps you could let the poster speak for himself?
BenParkinson26
Sightseer
Solution
Pete is correct, this is a wired test plugged in to router. I have tried plugging into the main white ufo hub but that makes little difference. I am often finding that I can get a faster dl speed over WiFi rather than internet which shouldn't be right. There's no issue with upload at all so really confused with this one.
OK, this has been flagged up to the support team for you, you can expect a response when they are back online tomorrow.
Hi Ben,
Have you tried speaking to the UFO support team?
Martin N
Newbie
I am having the same issues as you at the moment.
My wired connection shows a download speed of 95mbs,but when I use wireless I'm getting in excess of 350mbs.
Very strange behaviour as I thought a wired connection would show much better speeds.
When I had this installed the engineer plugged his laptop direct into the white box with the ethernet cable and showed me a speed of 1.2gb . I have since tried the same but still no difference 95mbs .
Don't understand what the problem is but hopefully get this fixed soon.
I know this doesn't help with your post/issues just thought I would share mine.
M Nettleton
joeyboswell
UFO Customer
@Martin N
Have a read up on 10/100/1000 NIC settings and capability.
As you are stating that you can only achieve 95, this falls inline with a NIC that can only achieve 10/100 at best (meaning no 1000 support).
Yes, wired should be faster, you need to provide details on the device you are trying that is connected directly, my guess is, it can only do (or set to) 100. Again, I am guessing an old PC or cheap laptop with only a 10/100 NIC.
Please post details of the device you are connecting directly!
Flagging things up to Talktalk response isn't going to magically fix your hardware restriction issue. So called senior talktalk support should know better!
Joey Boswell
