winmx new sagemcom 5364 router
5 REPLIES 5
tuffy2
How do you set up ports for winmx on new sagemcom fast 5364 router
What is Winmx & what sort of device is it runnng on? Is it working in a server mode to accept incomming connections from the web? What TCP or UDP ports do you want to forward to it?
tuffy2
ports   tcp 6699
           udp 6257
Winmx is a p2p shareing site
Login to the router & go to:-
Manage My Devices > Manage Advanced Settings
Click on the Windows PC in question, followed by the Port Forwarding tab.
In the new rule, give it a name then set these:-
Protocal TCP
External port 6699
Internal port 6699
Click Add
Then create another using a different name & set this:-
Protocol UDP
External port 6257
Internal port 6257
Click Add.
Then you will need to add an inbound rule to your Windows Firewall on your PC, or the 3rd party firewall if you use one.
tuffy2
That as done the job many thanks for your help
No problem, glad to help.
