Allow LAN network to be changed away from 10.0.x.x or 192.168.x.x - SSL VPN Clash
Submitted by bonbonizer 21-04-2020 | 1 Comment
Status: Not Right Now
Due to COVID-19 more people need to work from home however when you connect to SSL VPN if your lan range clashes then can cause issues. currently Talktalk router only allows local lan network to be changed to 192.168.x.x or 10.0.x.x talktalk should open this up so people working from home can change their LAN network so they do not clash with their companies SSL VPN ranges
Get more ideas related to: Broadband
What do you think?
1 Comment
OCE_Chris
Status changed to: Not Right Now
Hi bonbonizer,
Apologies for the delay, thanks for the suggestion
