Submitted by Weevie 20-07-2018 | 2 Comments
Why is callsafe not backup-able ?
It appears to be a poor copy of BT's "Call Protect" which has always had the ability to back up the settings - because when you switch off callsafe (or it gets switched off by itself) - and re-enable it - you will unfortunately discover that ALL of your safe list numbers are gone - which may cause you to ask "Why"
The answer is that TT was in such a hurry to clear its name after the hacking incident - that nobody even considered this requirement !
Get more ideas related to: Beat the Scammers
