Beating the scammers who use fake telephone numbers when calling
Submitted by agzol 29-01-2019 | 7 Comments
Status: Unable to Deliver
We get scammers calling us on our TT landline number where their number appears to be valid, but when checked it turns out to be inaccessible. For instance today we got a call from 01273065322 which is a Brighton area number. Because we have friends and relatives in Brighton we answered it and the caller claimed to be from BTOpenreach saying we have problems with out internet speed. I terminated the call immediately. Dialled the number prefixed by 141 but got a message stating it was invalid.
But this raised a question in my mind as to why BT (or TT?) can't check the calling number and block the call if it's invalid before connecting the call?
I know we could use CallSafe but what I'm suggesting could stop many scam calls at source.
Get more ideas related to: Beat the scammers
What do you think?
7 Comments
Thats a great idea. Another problem I have is a string of calls with the same message but the number changes every time -although the prefix number is the same - so no use for call safe. It needs some sort of a prefix/area code blocker.
Had the same problem today scam call from 016751079599 tried to check and report but number rejected as too many digits. Cannot find any other mechanism for reporting the number manually.
Problem Solver
Hi had 2 calls today and 3 yesterday  numbers were 01287971752 0128771556  purporting to be from Talk Talk technical department to cut of my internet I did not press any buttons as requested but put the phone down as this seems to be machine generated
mick
Status changed to: Unable to Deliver
@agzol Thanks for the suggestion. We do check if a valid number is presented. If no number is presented or it is an invalid number format then we do block these calls and 100's of millions of these calls are blocked each year, however scammers can spoof a phone number and there isn't anything we can do to identify them. We always suggest using our CallSafe Service to mitigate scammers. Thanks
All the calls I get start with 0138
Wizz Kid
Michelle - You say that TT intercept invalid number calls but they are unable to spot a spoof phone number. I use BT Call Guardian and it intercepts all calls that start with an automatic generated message. If I am expecting an important call I switch off Call Guardian because I don't want the caller to be discouraged by the Guardian procedure. As a result I also have scam calls coming through. If I call back any of these numbers I get, almost without exception, 'beep beep beep the number you have dialled has not been recognised'. Is it not possible to reject these calls before they reach my phone?
I would like to echo charlieboy99's comment and query.
