Submitted by bonbonizer 27-04-2020 | 0 Comments
It would be great to unlock the restriction on LAN IP. Specially now that more people are working from home and if you are working from home Usually there is a clash with 192.168.0.0/16 172.0.0.0/16 or 10.0.0.0/16 range so it would be nice to be able to change the lan ip range to something other then the ones shown above for example 100.67.67.0/24 then you can carry on to use network printers etc.
I did try and it just keeps saying invalid Ip seems the router is restricted to 192.168.0.0/16 10.0.0.0/16 and 172.0.0.0/16 any smaller subnets. I dont see why you would need to lock down the LAN IP range ?
Tried on my old sky router and it actually lets you change the LAN not locked
I get a feeling this will be update by the time my contracts runs out lol.
Thank you 🙂
