Improve DHCP Implementation on Router
Submitted by OrangeReaper 03-11-2018 | 12 Comments
Status: Investigating
  1. New ideas
  2. Investigating
  3. Accepted
  4. Delivered
Step 2 of 4
The provided WiFi Router implements a very restricted DHCP service as follows:
1. It cannot be disabled (this means that I cannot use another device on my home network as a DHCP server)
2. It does not allow addresses to be reserved for networked devices based on their MAC Address.
3. As a result of points #1 and #2 the Port Forwarding provided is strictly limited to devices that are always switched on or are manually configured to have a static address which is outside of the DHCP range.
My suggestion is to update routers to provide a 'more complete' DHCP service that addresses the above limitations.
Thank you
Get more ideas related to: Broadband
Thank you
What do you think?
12 Comments
Status changed to: Investigating
@OrangeReaper We have passed your feedback on to our Products Team who are looking into this issue. I'll update your thread once we have more information. Thanks
This needs to be addressed quickly, the ability to change the DHCP range is standard so this functionality must have been taken out which then mens it should be simple to add back in.
Enlightened One
 Otherwise you can get a third-party Rueter.  I use a FritzBox 7490.
 It works fine with fibre and ADSL with TT.
Prescol
Sightseer
Configure the interface of each connected router and change the IP address for the connected interface, its subnet address, and its subnet mask. Delete your current TTRockStars DHCP scope. Create a new DHCP scope with the new subnet mask. Enable the Conflict Retries option on the DHCP server.
@Betty52; I'm sorry your post makes no sense?
I have used a 10.0.0.0/24 range for approx 15 years on a BT Hub 3, 5, 6, sky q hub and a virginmedia hub with the first 50 range outside of DHCP. I came to talktalk and changed the IP to 10.0.0.0/24 range, this would not work at all, and even on the default 192.168.1.0/24 I cannot change the DHCP allocation to start at 192.168.1.51. I have had to switch to full DHCP for the first time in 15 years.
@jryan94, Thanks for underlining the problem. TalkTalk just not providing a service in-line with other service providers, my experience too. I expect to leave TalkTalk unceremoniously at the end of my contract, never to return. Profound lack of response to this issue being one reason.
The router restrictions are awful and I can't see why they should be in place.  Going to go back to my old router when I have time to stop the network.
I certainly agree that DHCP should be fully configurable. You should be able to turn it on and off, you should be able to specify the range, and optionally the gateway and DNS servers. It is perhaps appropriate for a consumer-grade router to sanity-check your DHCP range against what is configured in LAN subnet settings, but other than that you should be able to do what you like.
Unlike @OrangeReaper though I for one wouldn't switch from one service provider to another just because I'm not happy with the bundled router. If router functionality and configurability is that important to you, just get your own router from Amazon or Argos or Currys or whatever - and maybe consider putting OpenWrt on it. Like @prescol suggests. So I am in favour of making the router more configurable, though I am also in favour of restrictions that reduce the likelihood of the technical support crew's time being taken up predominantly by things that technologically-challenged people do with consumer premises equipment.
I just found (by accident) that it is possible to assign / reserve addresses for devices, as follows:
  • Goto the dashboard
  • Press "See Internet Settings"
  • Press "Manage Advanced Settings"
  • Click on the device that you wish to fix the IP address
  • In the page that results there is a button "reserve"; when pushed seems to have the desired effect.
