Powerline Adapter
Submitted by vaw001 07-09-2020 | 2 Comments
Status: New
  1. New ideas
  2. Investigating
  3. Accepted
  4. Delivered
Step 1 of 4
  1. Is there a compatible through plug powerline adapter. I am short on sockets?
Get more ideas related to: Community
Powerline Adapter
What do you think?
2 Comments
@vaw001 yes u can u tp link ones i have the follow and work fine with t/t system https://www.amazon.co.uk/gp/product/B01G5Q9E0O/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
for more help just post in the help side here in the relevent area and we and staff can help this is just for ideas of improvments
Sightseer
Hosay,
Thanks very much for the solution to the through plug powerline adapter problem.
Another way of fixing problem is to use a T shaped extension adapter with a through plug connection to the mains socket.  This allows you to use a standard powerline adapter.  This has worked for me.
vaw001
