Speed Test Results
Submitted by Barrowman 18-12-2019 | 12 Comments
Status: Investigating
  1. New ideas
  2. Investigating
  3. Accepted
  4. Delivered
Step 2 of 4
As a result of current and past problems regarding low fibre speed and buffering at times.
When using the 'Speed Test Checker' it would be nice to be able to see a record of previous speed tests, I'm aware that you are able to see them so why can't we?
I know this wont sort out a problem but it would be nice to be able to refer back and see if there is a obvious pattern to the problem.
Get more ideas related to: Broadband
Speed Test Results
What do you think?
12 Comments
@Barrowman why not post this in the fibre side on the help site to see what they say and what othere think about it
This is something which was available in the past and I am not sure why TalkTalk stopped it. There are of course third-party speed test sites which do allow you to record results over time.
Thanks ferguson
I do use Ookla as well as TT's but frequently come up with differing results than I get in this site, even though this site uses Ookla too....I'd just like to see TT add this back to their site.
Status changed to: Investigating
Hi Barrowman
Thanks for the idea, we'll look into your suggestion and get back to you
I've received an update about this. This is something that we'll possibly look into in future but there's no time frame at the moment - thanks again for the suggestion
The only speedtest worth using is testmy.net
It's not flash based which aggregates and is not a real world reflection of actual speed, it logs all your tests and can even be set up to run at set intervals, for example every hour and so on.
The best and most reliable speed test on the net (I have no affiliation with them)
This is my result from the last month, I am on the upto 40/10 package
https://testmy.net/compID/84651513073
@dgsection That's a matter of opinion. And what's Flash?  😉
A community star who has no idea what Adobe Flash is, guess you have no idea what Java is either lol 😭
HTML5 tests are so more accurate!
I have every idea, Flash is almost dead, I was being ironic. Do you not know?
Fair point, I guess I missed the emoji implying irony, sorry!
