shorter time before divert home calls on no reply
Submitted by TimTraylor 31-05-2019 | 6 Comments
Status: Unable to Deliver
I would like to make a suggestion that the call is diverted to another number of my choosing in a quicker time or after a time of my choice. People ring off before diversion takes place.
Would this be possible?
Get more ideas related to: Community Phone
What do you think?
6 Comments
Yes but how many people would want that do not think talktalk will look at change it
I agree Talktalk will not change this, but for those that do want a shorter time before divert, Talktalk could give us the option!
@hosay299 I find that potential enquirers ring off before the diversion takes place. Yes I realise if they wanted to contact you they should persevere, but you know what the public can be like.
Status changed to: Needs Info
@TimTraylor Hi, have you seen the below Help Article? Is this what you're referring to?
  • Dial 2 1 to divert calls instantly without having to ring. Perfect if you have problems on your line or if you run a business and have moved number
About Call Divert
Hi @
Yes, exactly.
We already use **61*
We need to set it to divert permanently, but still have the option to answer the call if we are able to.
Status changed to: Unable to Deliver
@TimTraylor Thanks for the additional info. Unfortunately this is not possible, however thanks for the suggestion. Thanks
