Broadband going very slow over past week.
Piyaitsapeq
Message 43 of 43
On Fibre 65, speed is usually about 70mbp, the last week it has been between 7 and 20 today. Have gone through all the suggested fixes and nothing is making it any better
42 REPLIES 42
Message 21 of 43
Ok thank you for confirming. Could you also run a wired ping and trace route and post the results into the thread please.
Run a Ping or Traceroute - TalkTalk Help & Support
Message 22 of 43
Yes, I did the 30 mins power down Michelle
Message 23 of 43
Can I just confirm, did you also try the 30 minute router power down this morning as the speed test results do look very low in relation to the current sync speed?
Message 24 of 43
Yes, it was wired. I have just tried another laptop also, and get 12.8
Message 25 of 43
Thank you. Can I just confirm that this was a wired speed test? Do you also have a different device that you can run a speed test on please?
Message 26 of 43
Hi Michelle, Just done that.
Test 1 through talk talk, speed to router 11Mbps
Test 2 through talk talk, download speed 26Mbps
I done a further test through an independent speed checker and got 10.0 Mbps
Message 27 of 43
I've re-checked the connection stats and I can see that the sync speed has increased. Could you try powering down the router for a full 30 minutes and then run another speed test please as this will reset the current session and can often increase the throughput speed.
Message 28 of 43
Hi Debbie,
Speed has been averaging 10 - 20.  Now using the test on talk talk, its showing on 5 to the router
Message 29 of 43
Hi Piyaitsapeq
Thanks for letting us know.
I will check in again with you on Monday to see how the connection/speed has been.
Message 30 of 43
New router has arrived, thank you. Speed at test showing 25.1,. See if it stabilises over the weekend, then I will let you know
Message 31 of 43
Message 32 of 43
Thank you Debbie, I will let you know, as soon as I try it. Thank you
Message 33 of 43
Hi Piyaitsapeq
Message 34 of 43
Thanks, that would be great Debbie
Message 35 of 43
Hi Piyaitsapeq
Would you like me to send a replacement router for testing?
Message 36 of 43
No, this is the only router I have
Message 37 of 43
Thanks for trying this. Do you have an alternative router that you could test with please just to rule this out?
Message 38 of 43
Yes I have done the 30 minutes, and done a hardwired speed test, it went up to 40, but has now dropped to 25
Message 39 of 43
I'm sorry to hear this and I will take a look now. I've run a test on the line which hasn't detected a fault. Can I just confirm, have you tried powering down the router for a full 30 minutes and then ran another wired speed test, as this will reset the current session and can often increase the throughput speed?
Message 40 of 43
As you are getting slow wired speeds, then I will ask the TalkTalk support on here to deal with this.
