Broken Firmware Update - Sagemcom Fast 5364 - (Again)
Olivia45
Message 15 of 15
So, again a firmware update has broken my internet connection...
My VPNs no longer work
WhatsApp calls don't work
Certain other apps not working
A number of DNS resolution issues
Fault has been reported (ref# available if needed)
Can somebody please escalate this and provide the necessary firmware rollback/update/reset as needed?
Once again, this update has clearly been rolled out prematurely, without sufficient testing or adherence to modern development best practice.
An updated GUI is not essential on a router - stability absolutely is.
You cannot keep switching customers to NAT without due warning (and thorough explanation of consequences)
Thank you
HW version = FAST5364 3.00
SW version = SG4K100158
GUI version = 5.79.4
NAT = enabled             <------- Why?!
14 REPLIES 14
Message 1 of 15
Hi @ComfortablyNumb
Please can you create a new topic/thread on the Community, we can then take a look at this for you.
Message 2 of 15
I have noticed I can no longer access the router ADVANCED SETTINGS option when I log into the hub from my iPad (or iPhone) - despite being able to log into the dashboard. I used to find it very convenient to have the ability to restart my router using one of my iOS devices without the need to go to the desktop computer. Is this a new bug or is this a feature of the current software version?
My software version appears to be SG4K100174
Message 3 of 15
UPDATE - Your router firmware has now updated to V174. This should resolve the firewall issue. Please let us know if you experience any further issues.
Message 4 of 15
Hi Olivia45
Our Devices Team are still investigating this issue but have advised that setting the firewall to medium should resolve the issue - it has been advised by our Devices Team that customers should set their firewall settings to medium.
Message 5 of 15
Hi Olivia45
I have passed this information to our Devices Team and I'm just waiting for an update back from them.
Olivia45
Message 6 of 15
Hi Debbie,
VPN wise, Wireguard and OpenVPN
TCP appears to work
UDP does not work
Neither does Wireguard
WhatsApp voice/video calls don't work.
Kik messenger chiefly among the steaming apps - haven't had time to check all of them, but I imagine more also don't work.
DNS - I noticed some issues on the morning of Fri 17th doing a cursory check of the logs.
Unfortunately I don't have time to trawl through the logs and find them now.
All of the above points to a NAT traversal issue - either a misconfiguration on your backend, or in the router firmware.
Message 7 of 15
Hi Olivia45
Our Devices Team are completing some testing and they have asked if you could confirm the below:
  • What VPN issues are you reporting?
  • What VPN protocols are you using etc?
  • Which apps are not working?
  • What DNS related issues are you experiencing?
Message 8 of 15
Hi Olivia45
I'm speaking to our Devices Team now and I will post back as soon as I have further information.
Olivia45
Message 9 of 15
Hi Debbie,
The firewall is currently set on high, however as I have already stated, setting it to medium does not resolve the issue.
Message 10 of 15
Hi Olivia45
Apologies, we are unable to roll back firmware.
What is the firewall currently set at? I can then pass this over to our Devices Team.
Message 11 of 15
Definitely start your own thread, @ggttjm, to avoid confusion between accounts etc.
Staff are likely to have finished work for the week on here, @Olivia45, so this is unlikely to be resolved before Monday.
ggttjm
Message 12 of 15
Piggybacking on this, but let me know if etiquette is to start a separate thread, very similar issues here, also on SG4K100158 now (as of yesterday/today?) and Sagecom FAST 5364 3
I had the same issues last May and the solution was a firmware roll back. Is another one available please? I was on
SG4K10002829t previously, and that was fine.
Setting Firewall to Medium security does improve matters, but isn't really an acceptable solution
Olivia45
Message 13 of 15
After checking Debbie, as I suspected that has not resolved the issue.
Furthermore I would not be prepared to leave the firewall on medium settings anyway.
NAT is what's causing the problem.
Please can the necessary firmware be rolled back/updated
Thank you
Message 14 of 15
Hi Olivia45
Please can you check the firewall settings and change this to medium and then retest?
