Dropping connection - getting worse
Bouch
Message 12 of 12
I have been a loyal customer for over 17 years, but since the start of 2024, I have experienced what seems like daily drop outs at varying times of the day and this is frustrating when working from home.  It can last from a few mins to longer.
My current contract  states speeds between 61.6 and 55.5 Mbps
The broadband speeds also have seen a considerable drop since the turn of the year (no new equipment added)   Example, TV Firestick used to record 60MB on 5GHZ wifi and today its 40MB and on 2.4GHZ its now 36MB.    I used an ethernet connection for my work PC and the speed test just now is 43.4MB download,  3.47MB upload, latency 10.9ms, jitter 1.52ms
Have been using a WiFiHub (FAST 5364-3 T8) for a few years now.
The connection tests - say there is a fault and then later it says its all working fine,  and this repeats almost daily.  Have rebooted router many times.
Existing case reference - REP-14261897
Very frustrated - please advise and help!
11 REPLIES 11
Message 1 of 12
Hi @Bouch
That's great. I believe the engineer completed work at the cabinet to fix this fault.
Yes please keep the new router 🙂
I've sent you a Private Message with a link to a short survey for the Community.
Message 2 of 12
Hi Debbie
Thanks for keeping me in the loop.   Now I am home, I have managed to test the speed.
Through ethernet connection I am getting
Via WiFi   2.4GHZ (a little slower than normal)
and on 5GHZ
I have optimised the WiFI channels as well.
So overall, it looks like it is back to normal. Did Openreach say what the issue was?
I am presuming I can keep the new router that was sent (as it took ages to reconnect the Ring system and smart socket devices).
Thanks for your @Debbie-TalkTalk  and @Karl-TalkTalk  help on this one
Message 3 of 12
Hi @Bouch
Openreach have closed the fault as resolved.
Is everything working ok now?
Message 4 of 12
Hi Bouch
I can see that the fault has been assigned to a line engineer this morning.
I will check on this again later this afternoon for additional updates from Openreach.
Message 5 of 12
Current speed test - so awaiting Openreach
Bouch
Message 6 of 12
New router installed this afternoon, as internet download speed had dropped to below 10MB today (it was ok yesterday evening). It made no difference (apart from having to reset all the Ring cameras, Echo dot and smart sockets!!!)    Ran a check on the line and it now appears that there is a fault between house and the exchange and its been referred to Open Reach.     Will report back in due course.
I note the router has digital voice capability - so at least that is handy for when this area gets switched over.
Paul
Message 7 of 12
No Problem 🙂
Message 8 of 12
Karla
Router has s arrived, so will test after BH weekend.
Paul
Message 9 of 12
No Problem 🙂
Bouch
Message 10 of 12
Thanks Karl, will report back once it arrives.
Message 11 of 12
Hi Bouch
A new router is on the way to rule out a hardware issue, before we take this towards an engineer for you.
Please test with the new router and report back here.
