IP Camera
Stivi2159
Message 7 of 7
Can anyone help.  I am trying to use a Dekco DC5L security camera.  The camera is visible in my TalkTalk Router device management list but I cannot find it on my PC.  Does anyone know how I can make it visible.  Any help/advice would be greatly appreciated.
6 REPLIES 6
Piethorne
Whizz Kid
Message 1 of 7
You may only be able to see the Dekco DC5L on a PC by using the CloudEdge app.
https://manuals.plus/dekco/dc5l-home-security-camera-manual
https://cloudedgeapp.com/cloudedge-for-pc/
I'm just a customer who might be able to help, not official help & support.
Message 2 of 7
That sounds like it is probably OK, but to be sure please can you post the full output from the command so I can check it for you?
How does the camera connect to the router?
Stivi2159
Message 3 of 7
Hi - I did that but don't know what it means, the result was;
Round trip times in milli seconds
minimum = 2ms, maximum = 2ms
Average 2 ms
Message 4 of 7
Can you ping the camera from the Windows Command Prompt with:-
ping 192.168.1.X
(where X is the last part of your camera's IP address)?
Stivi2159
Message 5 of 7
Hi - tried this but the webpage just comes up with 'refused to connect'
Message 6 of 7
Presumably, you just browse from Chrome or Edge etc to its IP address.
