Intermittent no internet connection
Bitter1
Message 13 of 13
Over the past couple of weeks I have been experiencing intermittent loss of connection to my various devices. It lasts maybe 5 - 15 minutes before returning. It effects both wifi and ethernet connections. The router light stays white while this is happening. There doesn’t seem to be any pattern or certain times that this occurs . Sometimes it is just the wifi that is lost then other times it’s ethernet connections as well . I suspect the router may be faulty. Any help would be appreciated .
12 REPLIES 12
Message 1 of 13
Hi Bitter1
That's great, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Bitter1
Message 2 of 13
Hi Debbie
I’ve had no problems with the connection since the replacement router was installed, it seems like
this has cured it . It would have lost connection numerous times by now with the old one.
Message 3 of 13
Morning @Bitter1
How's the connection been over the weekend?
Message 4 of 13
HI Bitter1
Thank you. I will check in again with you on Tuesday to see how the connection has been over the weekend.
Message 5 of 13
Message 6 of 13
Hi, the replacement router arrived yesterday, it’s been in use now for almost 24 hours with no problems. I’ll let you know how it’s going again in a few days . Thanks
Message 7 of 13
Hi Bitter1
Have you received a notification about the router delivery?
Message 8 of 13
You're Welcome 🙂
Message 9 of 13
Thanks Karl , much appreciated
Message 10 of 13
A replacement router has been ordered for you.
Bitter1
Message 11 of 13
Hi Debbie
yes that would be great if you could send me a replacement router. Thanks
Message 12 of 13
Hi Bitter1
The line test is clear - No faults detected.
Would you like me to send a replacement router for testing?
