Internet connection frequently drops out on TT, but OK on BT BB
jayesjay
Whizz Kid
Message 4 of 4
I have two phonelines with BB on each, I normally use TT, but if TT line BB drops out, I use BT line  BB.
In the last week , I have had several instances of TT BB internet dropping out (while phone lines remain OK). After a while TT BB inet comes back. But during the off period, the router light remains white (SAGEM FAST 5364).
The connection in my installation has a Local Network (RJ45?) cable from each router connected to my desktop PC via a simple switchbox. This enables use of BT BB when TT is down. No other cables or connectors are touched during such a switchover, and as both normally work well, I have to assume that the connection failure is not in this cable routing.
For TT, I have Fibre 65, fibre to the cabinet, I believe, and still get a d/l speed of about 30 bursting to 32 MB.. I don't know what the BT arrangement is, I normally get about 50MB.
3 REPLIES 3
Message 1 of 4
jayesjay
Whizz Kid
Message 2 of 4
I shall check if and when the TT Inet drops out. I can check if other WiFi or wired LNA equipment loses the inet.
Chris-TalkTalk
Message 3 of 4
Hi jayesjay,
Do you have any other devices connected to the router by wifi? If you do, do they also lose the internet connection?
