Router keeps rebooting intermittently
A13xeo
Message 15 of 15
Every day my router reboots about twice a day for no reason. I have replaced the router all the cables, removed everything from the router, changed power socket and connector, connected the router directly to the phone line Inlet socket and replace the phone line extension lead but it keeps rebooting.
My router is a EchoLife DG8041W Home Gateway.
Is anyone else having this issue or is there an alternative router that can be supplied?
Alex
14 REPLIES 14
Message 1 of 15
Hi A13xeo
Has everything been working ok since I updated the firmware yesterday evening?
Message 2 of 15
Hi A13xeo
I've made the change to your router firmware.
Please can you monitor the connection and let us know how it compares.
Thanks again.
Message 3 of 15
A13xeo
Message 4 of 15
Thanks Debbie it's much appreciated.
Alex
Message 5 of 15
Hi A13xeo
Yes I will update the FW just after 5pm and I will post back to confirm once it's been completed.
Please can you leave the router switched on at this time without rebooting.
A13xeo
Message 6 of 15
Hi Debbie,
Woukd it be possible to do it after 5pm today?
Alex
Message 7 of 15
Hi A13xeo
Apologies, it's been moved to moderated posts.
Here is my reply - I can make the change to your router firmware.
When would be the best time to update your router firmware?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 20 minutes to update.
A13xeo
Message 8 of 15
Hi Debbie,
I can no longer see the other topic.
Alex
Message 9 of 15
Hi A13xeo
I have posted on your other topic on the Community.
A13xeo
Message 10 of 15
Hi keith,
Thanks you it's much appreciated.
Alex
Message 11 of 15
I have asked one of TalkTalk's support to pick your thread up and upgrade it for you, only TalkTalk can do this.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
A13xeo
Message 12 of 15
I checked the user log and it looks like it's the kernel panic is causing the issue. I get the below error at the same time the router reboots.
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
Alex
A13xeo
Message 13 of 15
Hi Keith,
My current firmware is TalkTalk Wi-Fi Hub Version v1.05t please advise how I can upgrade to v1. 06?
Alex
Message 14 of 15
Are you seeing entries in the User Log about kernel panic? This is normally the cause of the reboots & requires the firmware to be upgraded to V1.06. When I know, I can arrange to get this done for you, as it only affects some DG8041W routers & not others, this is not normally an automatic update.
