Router not working
gordice
Message 22 of 22
Hi, when I turn my router on it flashes amber then flashes amber faster then no lights at all, I've tried everything, even resetting the router, any other advice or do I need a new router, thank you.
21 REPLIES 21
Message 1 of 22
gordice
Message 2 of 22
Hi Debbie, thank you, i will send it tonight.
Message 3 of 22
Hi gordice
That's great 🙂
Please keep the new router and can you return the old one using the pre paid returns bag.
Thanks again.
gordice
Message 4 of 22
Hi Debbie, yeah it's been ok,  no problems thank you, so do i keep this one and send you the old one or do i have to buy a new one ?.
Message 5 of 22
Hi gordice
How's the connection been over the weekend?
Message 6 of 22
Hi gordice
That's great, thanks for letting me know 🙂
I will check in again with you on Monday.
gordice
Message 7 of 22
Hi Debbie, yes i have received the new router, will set it up today when i finish work and see how it gets on, thank you.
Message 8 of 22
Hi gordice
Message 9 of 22
We'll check back in with you in a few days to see how you're getting on.
gordice
Message 10 of 22
Thank you very much Debbie, hopefully it will work, thank you.
Message 11 of 22
Hi gordice
gordice
Message 12 of 22
If you don't mind , thank you.
Message 13 of 22
Hi gordice
Apologies for this. Would you like me to send a replacement router for testing?
gordice
Message 14 of 22
Yes Debbie, i have had it unplugged all night and when i plugged it back in this morning it still wasn't working.
Message 15 of 22
Hi gordice
Sorry for the delay.
Do you still need help with this?
gordice
Message 16 of 22
Thank you.
Message 17 of 22
To get the best deal on renewing your contract is the loyalty dept as they have access to the best deals. Their direct number is 0345 1725157.
gordice
Message 18 of 22
Looking at some other comments on people who are having the same problem,  they've been advised to upgrade and they will get a new router, depending on how much a new one is will decide on what i will do, thank you.
Message 19 of 22
I am not sure how this will affect the cost of replacing the router if faulty or fixing the line. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
gordice
Message 20 of 22
Fibre 65 plus TV, but it came to an end on 21/06/23.
