Fibre 65 slow speeds even after numerous engineer visits
weston24
Message 16 of 16
I have Fibre 65 and have had issues with the it for months now. Sometimes I have days where the connection drops a lot which really affects my work, but I also consistently have slow speeds.
In August, I was only getting 20mbps instead of my "guaranteed 49mbps". An engineer was sent out and they moved my master socket and the speed went up to around 60mbps.
That speed didn't last for long though and I continued to have issues. Last week I went through all of the checks as I was again only getting 20mbps and an engineer was sent out but didn't need to come in the house. The speeds went up to 60mbps again, before going back to 20mbps a day later.
This week I raised it again and talktalk determined that an engineer was needed to fix it without needing to come into the house. Great, surely this time the fix will help.
I am now getting around 15mbps.
I have been through every kind of check and test for months now and no solution can be found. I don't understand how I can get the speeds but they don't last.
Do I just need to move to another provider? Or could the issue be something that wouldn't be fixed by that? Hopefully a different provider would be able to find the problem more efficiently than this though.
15 REPLIES 15
Message 1 of 16
Afternoon,
Ok thanks for letting us know. There is no issue using the test socket, it just means that the extension sockets won't work. (if you have any)
Message 2 of 16
I'm happy to leave it as it is and monitor, if there's no issue with me using the test socket?
Message 3 of 16
Hi again,
Ok thanks for confirming. Would you prefer to monitor the connection for a while longer at the test socket just to see how this compares?
Message 4 of 16
We don't have a phone so don't know and can't test sorry. At the moment, everything we use (just the router) is working perfectly whilst using the test socket.
Message 5 of 16
Good morning,
Thank you for the update. I've re-checked the connection stats now and the line test is detecting a potential line fault. Can I just confirm, is the voice service ok with no noise on the line at the moment? As soon as we've confirmed this then we can raise this over to Openreach as a broadband fault for further investigation.
Message 6 of 16
Leave it in the test socket till you hear back from staff, @weston24 (after the weekend).
Message 7 of 16
I connected to the test socket and I'm now getting 50-60mbps. Does that help determine the issue?
To confirm, we don't use any other socket in the house and the only thing that needs to connect to one is the router.
An engineer moved our master socket and switched faceplates a few months ago because our speeds were low, and it fixed them for a few weeks.
Message 8 of 16
Hi weston24
Yes of course. Please let us know once the phone, router and filter are connected to the test socket, we can then run another line test in this set up.
Message 9 of 16
Sorry, yes I do, still only getting around 13mbps, but I haven't been able to look into and find the test socket yet due to work. I will do so over the weekend and update then if that's ok, thanks.
Message 10 of 16
HI weston24
Do you still need help with this?
Message 11 of 16
Ok thanks. Have you tested with the router connected to the test socket? - Your guide to main phone sockets - TalkTalk Help & Support
Message 12 of 16
Hi Chris, many thanks for looking into this.
We don't use or landline phone or have one to test the line unfortunately.
Message 13 of 16
Hi weston4,
Line test is picking up a potential problem. Are you experiencing any problems with your telephone service, any noise on the line?
Message 14 of 16
Hi Debbie,
Thank you, I believe I have added these now.
Message 15 of 16
Hi weston24
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
