HUAWEI HUB DG8041W 2.4GHz WIFI Dies
Hiltophouse
Super Duper Contributor
Message 19 of 19
Hi, I've been living with this for a long time (I did have some older posts)
Every so often, average maybe once a week, all devices drop off 2.4GHz and are unable to connect
I can resolve by turning off 2.4GHz in advance admin and then back on again. No reboot of router needed and 5GHz can be left on.
Any ideas? I'm on firmware Version v1.06t
18 REPLIES 18
Message 1 of 19
Thanks for the update. What issue are you experiencing with the Chromecast?
Hiltophouse
Message 2 of 19
Hi, a long time ...but I did get a  5464 router and no need for any resets of 2.4 or 5 wifi. I do have a strange Chromecast type issue since have this router in place, but for ease I create a new thread and unrelated to this one
Message 3 of 19
No Problem 🙂
I'll check back in with you tomorrow.
Message 4 of 19
Hi Karl, not arrived as yet. Tracking says by 27 April.
Many thanks
Message 5 of 19
Has the router arrived ?
Message 6 of 19
Hu
Sure, I'll order one now for you.
Message 7 of 19
Could we perhaps try, in the hope I get the other model to try?
Message 8 of 19
We have the sagemcom 5364 and 5464 however we are unable to specify what model is dispatched, we only have the option to order the Wifi Hub.
Message 9 of 19
Is it still the SAGEMCOM FAST 5364 ? as thats what I had a couple of years back.
Message 10 of 19
we only have the option to supply the Sagemcom router, but some customers do use their own routers.
Message 11 of 19
The issue with Sagemcom was large file uploads locked out other network users as if didn't seem to balance bandwidth very well.
Can Talktalk provide a different router? such as eero, as I did recontract late last year without any router upgrade.
Message 12 of 19
Hi Hiltophouse
Apologies, we can only send the Sagemcom hub now, we don't send the Huawei WIFI hub out anymore.
Message 13 of 19
Apologies for the delay in responding, have been experimenting a lot. It seems that any manual channel or auto it still cuts 2.4gz wifi every now and again. To resolve I need to reboot router or trigger 2.4gz network off and on again.
I'd rather not go to the Sagemcom as that did have a different issue with large uploads locking out most other traffic.
Are there any other options please.
Message 14 of 19
Hi Hiltophouse
How are you getting on?
Message 15 of 19
Ok thank you for the update and please let us know how you get on.
Message 16 of 19
Hi, thanks for the offer of Sagecom hub but I'll experiment with channels first to see it that help. I did have a Sagemcom previously but that had issues with large uploads in the any sizeable upload would almost kill download.
The channel suggestion was interesting and worth trying and also I've never tried the Guest SSID when it stops working and that may provide some insight
Message 17 of 19
Hi Hiltophouse
Would you like me to send you a Sagemcom hub to see how the connection compares?
Skynet_TX
Message 18 of 19
Hi @Hiltophouse,
Have you tried changing the channel that the router broadcasts the 2.4GHz signal on, just to see if this is Wi-Fi interference related, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
