IP address
Milly2011
Message 3 of 3
I can get into some of the apps
You don't have permission to access "http://www.tui.co.uk/destinations/your-account/managemybooking/login?" on this server.
Reference #18.23f61002.1713381802.206e0c87
https://errors.edgesuite.net/18.23f61002.1713381802.206e0c87
How do i change to get into the above?
Chris-TalkTalk
Message 1 of 3
Hi Milly,
How are your getting on, has ferguson's advice helped?
Message 2 of 3
You got any ad blockers, or pop up blockers active? Disable if necessary. Which browser are you using and have you tried a different one?
